Alternator troubles
Posted by Zachary Hoyt on June 19, 2010 at 04:50:33 from (184.8.236.115):
I put a new Delco 10SI alternator on my H to replace another one that stopped charging. The new alt worked great for about 2 months and now when I pull the knob to charge the ammeter shows a slight discharge, around 5 amps. The battery voltage drops when I pull the charge knob and then whe I push it in again it rebounds. The PO rewired the tractor right before I got it, so I haven't worked on the wiring at all. Is this just an internal alternator problem or could I have a wiring problem that is killing them slowly? Any advice is very much appreciated.
Zach
