Posted by IH fan on June 19, 2010 at 07:38:39 from (69.148.146.89):
In Reply to: 404 parts help posted by sflem849 on June 19, 2010 at 07:19:26:
Check to be certain it's not just the keyway and arm on the bottom. If it is loose there, it's possible to rotate the gear/shaft 180 and cut new keyways in the shaft and arm. On my 240U, the gears looked like new, but the shaft (one piece with the gear) and arm were shot. It had already been rotated 180, so I had to replace the parts, but it had evidently been re-worked at some time. Easy to see... if the nut on the bottom of the shaft starts to rotate before the arm, that's the problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
