Re: 450 motor in 460
Posted by High Octane on June 19, 2010 at 10:03:14 from (4.225.88.206):
In Reply to: Re: 450 motor in 460 posted by Andrew Z on June 18, 2010 at 19:27:53:
third party image
I was gonna put this in a 300!!
This is a M block with a 460 rear plate. The second set of lower holes were drilled and tapped. These are H rails,,,, but the 460 rails would make it all right! Just redrill the frame rails to use the M side mounts.
I was gonna redo a 350 flywheel to fit the M crank. Low rpm operation and good equipment, you can make it workout.
Good Luck! HO
