Re: 360 engine
Posted by mkirsch on June 19, 2010 at 13:58:30 from (67.253.216.24):
In Reply to: 360 engine posted by jeremym on June 18, 2010 at 18:02:58:
It will fit in the large frame or small frame tractors, depending on which front and rear mountings you put on the engine.
If you put the front and rear plates off a D312 from a 666 on the engine, it will fit in a 460, 656, 666 or 686 (small frame).
If you put the front plate off a D312 from a 666 on the engine, and the rear plate from a 766 or early 886, it will fit in the 06 and 56 series large frame tractors.
If you put the front and rear plates off a D360 from a 766 or early 886 on the engine, it will fit in 66, 86 and 3x88 series large frame tractors.
There are other issues such as hood fit and radiator hookup, to mention a few, to deal with.
