Cub thermo-syphon cooling (cleaning)
Posted by cskent on June 19, 2010 at 15:11:35 from (24.166.237.20):
Hi all, I would like some suggestions on flushing and cleaning the radiator and engine on a Cub that I think is running too warm. Unless someone can give me an idea of what the normal operating temp would be. The motor cuts out under load when operated for a while. Seems to run fine when cold under load. No radiator leaks or overflow, just seems hot to me. Might be ignition, but I replaced contacts and condensor last season. What temp would be normal? can check with infrared thermometer, but not sure of best place to check temp. Thanks
