Re: Picture of Picture MFWD M
Posted by Wardner on June 19, 2010 at 17:27:49 from (4.154.236.36):
In Reply to: Re: Picture of Picture MFWD M posted by DeltaRed on June 19, 2010 at 12:18:41:
Delta,
You can't use the belt pulley drive gear. Power has to come from the main shaft, ring gear, bull pinion shafts, bull gears, or axles. Elwood obtained their power from the 4th/5th slider when it was not engaged. I have an early Elwood. I don't think that gear is functional in 4 wheel drive. It is slid back and won't make contact with the Elwood gear. R, 1, 2, 3, and 5 are OK. TA should be alright but someone welded up the planetary gears on my 660 so I can't test it. My Elwood will fit all the M, W-6, 400, 450, 560 with minor modifications.
Here is one shot of the transfer case. I got a whole lot more.
<a href="http://s140.photobucket.com/albums/r16/Wardner/?action=view&current=creeper110.jpg" target="_blank"><img src="http://i140.photobucket.com/albums/r16/Wardner/creeper110.jpg" border="0" alt="Photobucket"></a>
This post was edited by Wardner at 08:51:13 06/20/10.
