The slotted hole is used when you have a magneto which you do not have to adjust the fine timing. On your battery ignition unit you set fine timing by rotating the dist itself, basic timing is done with gear between dist reduction drive and that housing with slotted hole, just pull that shaft out and mesh it where you need it. If you pulled the whole works off and didn't note timing you will have to of course start from scratch. You most likely know this but anyway, pull number one spark plug, turn engine until you feel compression with finger in hole. Continue to first mark on pulley of the two marks close together. Rotate rotor to point to number one wire on cap in normal direction of rotation, and adjust to where points are just starting to open.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
