I believe you are talking about the hydraulic lines between the hydraulic pump on the front of the tractor to the remote valve which is operated with the lever on the light bar. If this is the case my cousin had the same problem and had them silver soldered which held for a while. I'm guessing vibration is the cause for the failure. He is a top notch machinist and to really fix his tractor he taped threads in both the pump and the remote valve and installed pipe thread fittings and had hoses made up between the two fittings. He's never had a problem since. I guess I'm lucky but my Super C has the fast hitch and same components as yours and haven't had to face the problem yet. Hopes this helps, Hal.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
