Re: 364 international PTO
Posted by Jimb2 on June 20, 2010 at 12:38:55 from (99.240.236.11):
In Reply to: 364 international PTO posted by Danny Neel on June 20, 2010 at 07:08:55:
Danny, OOPS, I was mistaken about having to remove hydraulic housing to fix item 4. I found this post in the archives:
Check to see if the PTO engage lever has possibly come disconnected from the sliding collar. This has happened twice on ours with the PTO engaged. If my memory is correct there is a roll pin that breaks on the engage lever. Not hard to fix, just take out three bolts on the PTO lever and pull the assembly out, replace the roll pin and re-install.
JimB
