Re: M-W in Farmall H
Posted by D Slater on June 20, 2010 at 13:27:57 from (71.164.39.43):
In Reply to: M-W in Farmall H posted by 79redcub on June 20, 2010 at 10:38:04:
With the following M&W piston sets all piston bores are 3-7/16 and all horse power numbers are M&W advertised. Set # SP-70 with a 6.4 compression ratio using a 8043 head 34.6 HP.
Set # SP-72 with # 8043 head 8.0 compression ratio = 35 HP. Maybe tested on LP gas or recomended for gasoline above 4000 feet.
Set # SP-72 with heads # 6186 and 8776 at 6.4 CR = 33.4 HP.
Set # SP-71 with heads # 6186 and 8776 at 6.0 CR. = 32.1 HP.
