Re: Pictures of that odd lift-all lever
Posted by JLE on June 21, 2010 at 03:30:25 from (173.123.54.112):
In Reply to: Pictures of that odd lift-all lever posted by Wild Bill on June 20, 2010 at 19:08:10:
If you have a double acting valve for remote control cylinder, you hook the lift rod in lower hole, pull rod back, drop over the little pin & puts hyd pump on pressure to supply remote system, I hope this as clear to you as it is to me. :-) JLE
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
