IH 340 utility won't start only by pulling it
Posted by Brian Peppler on June 21, 2010 at 04:59:44 from (205.213.216.254):
Hello This weekend I went to use my 340 and it would turn over but it would not start. It sits for month or two between use. I checked for spark on a plug wire nothing. cleaned points still nothing so I hooked a chain to it and pulled it with a tractor went 100 yards and it started up. I ran it for 5 minutes and shut it off it started up every time after that. ? what would it be that would not let it fire with the starter it is 6 volts Thank you
