Re: Mag vs Dist
Posted by Red Dave on June 21, 2010 at 09:12:10 from (66.216.141.163):
In Reply to: Re: Mag vs Dist posted by Jeff Z. on June 21, 2010 at 08:42:41:
Just dry your tears and put on your big boy pants, then go out and play. You'll feel better in no time.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
