"Tractor Vet" is on the right track but before going to the expense of an overhaul I would check out a couple things first. One would be check the the engine timing, may need tweaked a little. Other would be to be sure the starter is turning over fast enough, that would include checking out the battery cables, & etc.
Son & I bought a 1206 to restore a few years ago and anytime temps got under 50º it would take a snort of either to start. We retimed the engine which helped a little b ut found the main culprit to be the starting system. Ater having the starter rebuilt, put on new cables & replaced the relay & junction block under the steering wheel it starts up like new. Has to get well below freezing now before it needs a sniff.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
