Thank Jim, thanks before about where to find adjustment posts, I found it in the manual, and yes the adjusting screws are down all t way flush with lock nut, so My guess i need them relined.
Here's the tricky part- figuring out how much lining material the brake/truck reliner should add. At my delaer $625 not sure if that was each, probably won't want to order them, so i can get the thickness of lining.
I wish there was a spec somewhere, my only other thought was put the forward engagement band in (this is thinner one .202 or 5.5mm and tight screw down all the way flush again, then back it off till it comes up an 1 1/2 out of tight, and see what it looks like it would add to thickness to be tight again. Kinda a micky mouse way to do it though,
So you se my dilema what would the brake shop ask me likely- how thick of a lining
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
