Re: 684
Posted by Jimb2 on June 22, 2010 at 16:56:31 from (99.240.236.11):
In Reply to: 684 posted by Iron Appraiser on June 22, 2010 at 16:06:16:
First are you sure the filter and screen were installed correctly?
To Prime hydraulic pump, first try pressurizing the transmission by putting an air gun in the dip stick hole.
If that dose not work turn tractor off, place a clean bucket under the MCV valve, loosen the hydraulic line (power steering pressure) on bottom left of MCV valve, start tractor and run engine at fast idle until hydraulic oil comes out. Shut engine off and reconnect PS line.
JimB
