Re: F 350 Gaining Oil
Posted by El Toro on June 23, 2010 at 05:52:54 from (74.103.74.58):
In Reply to: F 350 Gaining Oil posted by Salty on June 23, 2010 at 04:43:54:
third party image
Your pump probably has a groove worn on No11 as shown in this pic. It doesn't cover your pump, but your's may be similar. A speedi-sleeve is used to cover that worn surface. The old seal usually causes the wear. The wear is probably in that area beyond the woodruff key before the gear. No4 gets brittle from age and causes the wear. Hal
