Re: Farmall 766 steering
Posted by pete 23 on June 23, 2010 at 10:22:32 from (173.87.147.99):
In Reply to: Farmall 766 steering posted by Gorman on June 22, 2010 at 18:02:04:
Have you checked the flow and pressures at each steering line at the front axle. Just a bucket to catch fluid will suffice. Check both at same time for flow and individually for pressure. If not the same problem is still in steering hand pump orbital valve and motor. If they are the same problem is in cyl or front axle assembly. I had a weird one once upon a time, steered one direction fair, other way was very hard,spindle was rusted almost solid in knee.
