Re: front wheels - 806
Posted by Weldon K on June 23, 2010 at 18:56:05 from (98.16.38.201):
In Reply to: front wheels - 806 posted by ChrisLSD on June 20, 2010 at 10:49:45:
I can see that toe in or toe out alignment of both front wheels would wear out the tires, but I can not see it causing a problem that would necessitate replacing the wheel ( rim ). It could have been damaged in some other manner and if your wheel ( rim ) is cracked or broken or has wallowed out lug bolt holes , yes replace it. As someone else said , it sounds as if you need to replace the spindle ( technically called the steering knuckle )and the steering knuckle arm and bushings. Those parts are available from several aftermarket suppliers and can be ordered from here at YTmag also. Look under "Marketplace" in top left corner of this page. Click on "Tractor Parts" and go from there.
