HELP oil fill question on IH 140
Posted by H2hines on June 23, 2010 at 19:06:29 from (75.235.193.64):
Hello all first time on board here. I am the proud new owner of a 1964 Farmall 140. Here is the question and i know it sounds crazy. I know where to check the hydraulic fluid. I know where to check the trans fluid. I think i even know where to check the engine oil (dip stick). Where do i put engine oil in? There is a fill port on the hydraulic pump that the previous owner (didnt know anything) told me is where engine oil goes. I dont think so. I have drained the oil from the engine and took almost 2.5 gallons out. I guess the best question is where do i put engine oil and where do i put hydraulic fluid? Also if you over fill the hydraulic fluid will it run into the crank case? Ok that a lot of questions. Thanks in advance for any help.
Jim
