Posted by Armand Tatro on June 23, 2010 at 21:17:49 from (98.227.136.134):
In Reply to: 706 with d/282 posted by jack 101 6 on June 23, 2010 at 17:21:05:
Not sure about the D282 in a 706 but on a 560D with D282 there is a rubber hose from the final filter to the fuel pump. Use the shut-off at the tank. Take hose of fuel pump. Open fuel tank and catch fuel in can.(might need extra person to turn fuel on and off.) Let fuel run for 2 min. should be FULL FLOW NO DRIZZLE. iF ONLY A DRIZZLE after 2 or 3 min. you might have a bad hose. Try new hose and see what happens. I have been using a 560D for 45+ years and had to replace two hoses. Also check priming pump if your tractor still has one. Let us know what happens. By the way when you reconnect the hose to the injector turn fuel on and bleed hose before tightening fitting. Armand
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
