Re: 706 with d/282
Posted by Allan In NE on June 24, 2010 at 04:19:37 from (148.66.88.254):
In Reply to: Re: 706 with d/282 posted by jack 101 6 on June 23, 2010 at 20:09:47:
Hi Jack,
The trouble with those big frame tractors is that ya can't pull 'em down the road at 15-20 mph to start 'em. :>(
Does that old sister have an engine heater? If it does, plug 'er in for 4 hours to get it darned good and hot, pump it up tight with that manual fuel primer and with a monster set of a batterys, give it another try. If you can get it to spinning at a real good clip, it "might" run.
My point here is that those compression readings are awfully darned low. From your figures, looks to me like you've only got one cylinder with enough umph to even ignite. Like to see compression on diesels at a minimum of 275 and upwards to around 400 lbs.
Thus, the reason for it "Smoking grey/black and wanting to start".
Now, on the other side of the coin, I've been able to get some really tired old diesels to pop/run after installing a new injection pump and a new set of injectors.........but still, that's a $2K gamble if you're reasonably confident in the accuracy of your compression tester.
As always, this is just my opinion and stated as such,
Allan
