On the bottom of the bell housing there is a mark on the flywheel and you have to look thru the hole towards the bottom of the bell housing. Do you have a mag or a dist. If you have a mag there is no timing it fires atTDC then goes to 33 0r so degrees. The dist will have a curve in the timing as the speed foes up as the dist has an advance curve.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
