Re: Farmall C Cam Gear
Posted by Janicholson on June 24, 2010 at 18:33:32 from (64.61.211.71):
In Reply to: Farmall C Cam Gear posted by kfallsalan on June 24, 2010 at 18:05:57:
I would only use it if the chip was less than 5 percent of the tooth. Then only if the chip was out of the main wear patch. I assume a used gear.
and the need to make it run. Otherwise get a different gear (and your money back) Jim
