Re: farmall cub brakes
Posted by Richard Rahmier on June 26, 2010 at 06:42:05 from (64.91.48.232):
In Reply to: Re: farmall cub brakes posted by ericlb on June 26, 2010 at 05:57:14:
Its fairly easy. I took out 6 bolts that hold the final drive on. two bolts that bolt the drawbar to the final drive. You should have a hoist to lift the final drive. their is a seal inside so be careful with that once you have it pulled back be careful cause the final drive can spin down on its own. once you have it apart the brakes just pull out
