Posted by mike paulson on June 26, 2010 at 13:06:53 from (98.15.178.36):
In Reply to: Re: Gas tank posted by Jeff Z. on June 26, 2010 at 09:45:33:
take the steering wheel off (using a beefy puller and wacking the puller drive bolt with a hammer as you tighten)and then remove the cluster section of the body, this will require undoing the throttle linkage and wiring/cable for the gauges, you can just kinda hang the dash/cluster section on the steering column, don't have to totally remove it. the tank is only held in with a few bolts from the side and will be fully exposed at this point, but first you gotta remove the fuel line etc and with the cluster out of the way it makes the job pretty easy. also be able to clean out alot of crap that gets caught up behind the gauges whilst your at it....
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
