Re: Super C stalls after running 30 min.
Posted by Jeff Z. on June 26, 2010 at 13:56:48 from (72.228.48.9):
In Reply to: Re: Super C stalls after running 30 min. posted by Erik Dekeyser on June 26, 2010 at 13:47:42:
Even if the bowl is full of gas it still may be plugged were it enters the bowl at the top of the sediment bowl assembly and gas from the tank can"t flow and push the gas through the bowl.
Many times a person thinks since the bowl is full there is no problem.
Even when you run out of gas the bowl is still full with a gravity system.
