Posted by Jim Broughton on June 26, 2010 at 19:21:02 from (209.86.226.14):
In Reply to: farmall M question posted by wally b on June 26, 2010 at 19:10:51:
Wally : I would leave the drawbar in the center, unless the plow does not throw the turnover sod next to the right rear tire....then you might wnt to shift the drawbar to the right and secure with a pin. If the two bottom plow (what size?) is matched to the "M" then the thing should work just fine in the center. You want you right tires to "drop-in" the furrow so that sod is plowed without any "skips" or bare spots. Good Luck !! Jim B.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
