Re: Alternator conversion on MD
Posted by Brad Motheral on June 27, 2010 at 06:18:04 from (96.63.36.141):
In Reply to: Alternator conversion on MD posted by BruceS. on June 27, 2010 at 04:59:00:
need more info. did you try switching batteries? clean posts? good heavy duty battery cables? if not start there. also make sure it's switched fully over to gas before trying. if there's no spark check manifold cut-out switch. when switched over to diesel this switch grounds the mag.
