Went through the same thing before restoring mine to be able to use it and really don't think the filter helped much. You can find an inline fuel filter which will work with a gravity system as noted by Gene Bender. If you have a tank venting problem no filter will help with that issue as that requires a different approach for a solution as noted previously. I found the real solution to my problems I had was having the tank cleaned really good by a radiator shop during the restoration and getting what junk was in the tank out. I then sealed it with one of those fuel tank sealing products from an auto parts store recommended by the radiator shop. I haven't even had a hic-up from it since and it is my favorite hay rake and check out the farm tractor so it gets used. Hope this helps, Hal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
