Posted by D Slater on June 27, 2010 at 12:27:04 from (72.65.138.236):
In Reply to: Super WD9 posted by Ethan Chamberlain on June 27, 2010 at 09:53:40:
Most times when those diesels are stuck the head will probably need removed. Unless you remove the valve cover and get all valves open and including a starting valve opening check, the penetrate won't make it. May want to remove injectors and if you get it unstuck without removing head worry about the plug then.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
