Re: Adding a hydraulic circuit to a 300U
Posted by ChrisNH on June 27, 2010 at 20:06:19 from (75.67.227.170):
In Reply to: Re: Adding a hydraulic circuit to a 300U posted by Cub149 on June 27, 2010 at 19:33:44:
OK, so the small block that bolts beneath the
handle valve isn't a check valve. You know what a
standard single-circuit Hydra-touch mounted on the
tractor looks like - I basically have the outside
portion of that with the block below it that has
the hose ports coming out the side. The problem
is, that block was only designed to work with
something else between the main block and tractor
- there just isn't any room with the hoses coming
out toward the tractor. The guy who sold me the
hydra-touch assembly said it would work fine.....
I didn't think about the clearance issue. I guess
I need whatever is normally on that extra front
port that is capped on a single-circuit tractor.
