Re: Two questions pertaining to my F400...
Posted by Wardner on June 27, 2010 at 21:05:15 from (4.154.237.109):
In Reply to: Two questions pertaining to my F400... posted by Crazy Red Power in SE-WI on June 27, 2010 at 20:12:21:
Fifth is not really a gear. It is a coupling kinda like a Lovejoy coupling but with many more fingers. The other gears have to travel across the mainshaft about an inch. Fifth only needs half that or less.
Fifth locks the transmission input shaft to the differential pinion gear which is part of the mainshaft. No power goes to the countershaft unless you are using the PTO on non-IPTO tractors.
Next time you are operating your tractor, grind me a pound, please.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
