The H is positive ground. The small tank originally was for gasoline to start the tractor on and then you switched to the large tank which used kerosene. Most of these tractors had the line from the small tank disconnected years ago and it just burns gasoline from the big tank. If it hasn't been monkeyed with there should be a heat shield over the manifold,a baffle in the exhaust and shutters on the rad. You started on gasoline, switched over to kerosene , closed the shutters until you heat guage was in the "Run"...the heat shield and shutters made the tractor run hotter and thus more efficient with kerosene. My Dad ran an M on kerosene during WW2. He said the tractor set up properly for kerosene would pull like a trooper and seemed to have slightly more power than running on gasoline. You had to know what you were doing when you set up for burning distilates. Those tractors were designed for distilates rather than gasoline.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
