Re: 1941 FARMALL H BATTERY CONNECTION FUEL
Posted by El Toro on June 28, 2010 at 08:37:05 from (74.103.74.58):
In Reply to: 1941 FARMALL H BATTERY CONNECTION FUEL posted by ala4bam on June 28, 2010 at 07:59:46:
If the tractor is still 6 volts the + positive terminal would be grounded. Your tractor may have been setup for using kerosene and gas was used in the small tank for starting. Then the big tank would contain kerosene. You could use the small tank for a reserve tank and fill both with gasoline. Hal
PS: The 10-20 we had had that small tank and we never used it since we used gasoline. Gasoline was only 16 cents a gallon. It may have been cheaper since we had a storage tank on the farm. Gas was 19 cents when I got out of the Army in 1955.
