Re: 1941 FARMALL H BATTERY CONNECTION FUEL
Posted by ala4bam on June 28, 2010 at 08:51:55 from (173.157.84.25):
In Reply to: 1941 FARMALL H BATTERY CONNECTION FUEL posted by ala4bam on June 28, 2010 at 07:59:46:
So I just run regular in the tractor. is that the appropriate fuel to use. I read when changing the oil and running it, it was good to know if Non detergent or Detergent oil was run in it. It look to be pretty much all original and had set in a garage for many years but was occasionally cranked up. I bought it at an auction. It was an original owner who had passed away.
