Re: 560 clutch slips???
Posted by mkirsch on June 28, 2010 at 09:43:01 from (64.80.108.56):
In Reply to: 560 clutch slips??? posted by higgi on June 26, 2010 at 07:30:16:
Did it slip before you adjusted it?
I certainly hope you did not continue to run it with the clutch slipping after you discovered the problem, if it was not slipping before... If so you will be tearing the tractor apart to install a new clutch.
