Re: WD9 3 point hitch
Posted by Wardner on June 28, 2010 at 10:28:56 from (4.154.234.118):
In Reply to: WD9 3 point hitch posted by Brad Motheral on June 28, 2010 at 05:34:42:
There is not alot to bolt to on a 9 series but I think an after market IH row crop 3ph could be made to fit somehow.
The picture of the 650 fast hitch probably won't help because you can't even see the main attaching plates. There are 9 individual pieces plus the 706 and 560 parts. There are also two con-rod bearing caps that secure the rockshaft. I chose to go with two lift cylinders.
third party image
This is the template for the side plates. It is made out of 3/4" plate. It attaches to the 1" holes at the top of the axle housing and two 3/4" bolts where the axle housing bolts to the transmission housing.
third party image
You should think about U-bolts around the axle housing that will hold a pair of heavy plate adaptors. Bolt the Worksaver to them. Run torque arms to the 1" holes. I have an extra Worksaver. Are you near eastern MA?
