you have a distillate H. The small tank was for gasoline to start the tractor on. The large tank held Distillate tractor fuel (not quite gas, not quite kerosene, and not made anymore). When the engine was warm, the operator turned off the gasoline, and turned on the distillate.
Good news is, you can run gasoline in it full time, so fill the large tank with gas.
If it has an alternator, odds are it is a 12 volt system, and should be wired with the negative to ground. If it has a generator, odds are that it is a 6 volt system, and the positive post should go to ground.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
