Re: M modified hydraulics
Posted by M Diesel on June 28, 2010 at 14:08:11 from (12.24.61.12):
In Reply to: M modified hydraulics posted by Mel in OR on June 26, 2010 at 19:04:50:
As long as the tank is vented somewhere, you can cap off the old vent. Otherwise remember that you are pumping oil in or out of the tank, creating pressure problems.
You might consider rearranging the return plumbing to be a straighter path. People usually just insert a T into the filler, and the return oil splashes real bad at the T, seeking to exit out the filler. With the felt inside the cap things are normally okay. Not great, but okay. If the cap is missing the felt, it gets ugly.
