Re: IH 424 Radiator (Repair or Replace?
Posted by CNKS on June 28, 2010 at 17:42:08 from (216.144.104.128):
In Reply to: IH 424 Radiator (Repair or Replace? posted by LJS30 on June 28, 2010 at 12:50:24:
I don't see the crack, but I typically use JB weld for that type of thing, it works fine. It is not under pressure so there should be no problem.
