Re: Wire Wheel or Sand Blast
Posted by Dave_Id on June 29, 2010 at 07:30:42 from (63.246.177.253):
In Reply to: Wire Wheel or Sand Blast posted by CubOwner on June 29, 2010 at 07:06:25:
Go to archives on "Tractor Restoration", hundreds of past discussions about pro and cons. I had a small sandblaster that held about 5 gallons of media and used it to sandblast 3 tractors. It can be time consuming. Moisture in my system was a huge problem. It was such a problem that I actually left the drain on the water separator open slightly to continue draining off water. I used a small carbide tip for my system. If you sandblast, you need to get as cheap as possible media, but it can't be too large or your tip plugs up. If you have a way to reclaim the media, that would be a big savings.
