Sandblasting is by far more effective at cleaning up an old tractor, but you should never sandblast "assemblies" that you don't intend to disassemble. (engines, transmissions, or anything that has bearings, oil, etc in it.) Sand will get in places you can't imagine, despite your best attempts at sealing them off. I've been restoring tractors for 27 yrs, doing "empty main case" restorations. Sandblasting is the easiest and most effective method I've found to clean up parts, but care must be exercised to clean out all of the sand after blasting. I use a wire wheel to clean up assemblies that I am not going to take apart, (if I'm doing repair work, not restoration work.) Use your best judgement, but remember that incorrectly used, sandblasting sand can cause you major headaches down the road. Also, use caution when sandblasting. There are health hazards associated with inhaling some of the media used. A respirator should be used if not doing "cabinet blasting."
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
