Re: Wire Wheel or Sand Blast
Posted by mkirsch on June 29, 2010 at 09:37:34 from (64.80.108.56):
In Reply to: Wire Wheel or Sand Blast posted by CubOwner on June 29, 2010 at 07:06:25:
If you're not careful you can seriously warp the sheet metal with a sand blaster.
Even if you're careful, sand will get into every seal and gasket on the tractor, so IMHO sand blasting is only for when you completely tear the tractor down.
You're not going to sand blast an entire tractor with a typical shop compressor and one of those cheap blaster kits from Harbor Freight. You'll die of old age, because you can only blast for a few seconds before you have to stop and let the compressor catch up.
I am addicted to those twisted wire cup brushes for a 4-1/2" angle grinder for this kind of stuff. These easily take rust and loose paint off, and feather out the leftover paint. I've done a complete tractor, a plow, and a loader so far. It takes far less time than you think.
