Re: farmall H transmission/5th gear
Posted by John M on June 29, 2010 at 17:36:26 from (67.231.160.184):
In Reply to: Re: farmall H transmission/5th gear posted by dremling on June 29, 2010 at 15:04:22:
Its right.Look on the edge of those machined teeth youll see kinda rounded off sections on each tooth, thats where the slider goes.If your top is off you should be able to slide those gears together, may have to wiggle it a little, or push in the clutch pedal.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
