Re: H fifth gear jumps out
Posted by Haas on June 29, 2010 at 17:54:57 from (70.202.228.107):
In Reply to: H fifth gear jumps out posted by jerry hakenwerth on June 29, 2010 at 17:02:10:
You really can't see the condition of the 5th gear very well until you take it out. When the gear is in neutral, you may be able to see a little. The gear is really a coupler that connects the input transmission shaft to the top transmission shaft so it is direct drive through the transmission. The popping out of gear problem is most usually that the internal teeth on the 4th/5th slider gear have worn down from grinding the gears. The second reason is the at the pilot bearing is worn out and has play. It will be side to side play, not front to rear. If you have any play in the rear top shaft then that would indicate the pilot bearing is worn. I'm assuming you have a parts diagram so you can see how the thing goes together.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
