Re: H fifth gear jumps out
Posted by Janicholson on June 29, 2010 at 18:27:43 from (64.61.211.15):
In Reply to: H fifth gear jumps out posted by jerry hakenwerth on June 29, 2010 at 17:02:10:
Haas is accurate.
I think the teeth can also be seen with the slider all the way into forth. The splines only engage about 3/16 of an inch, so it takes little wear to taper the splines on both the input shaft, and (less visible) the internal splines on the slider.
A new input shaft (or very good used, checked carefully) and a new 4th-5th slider will fix it. If noise is no issue, that is the way to go. If 4th noise will bug you forever, Replace the 4th counter shaft gear as well, with a running mate, or new. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
