Posted by Zachary Hoyt on June 29, 2010 at 18:39:38 from (173.86.125.77):
I got the new coil and condenser in the mail today. I put the condenser in, nothing happened. I changed the coil and then I had spark. I set the timing and drove about 3/4 of the way home, at which point the tractor died again. Now I have continuous 1/4" blue spark when I test the coil but nothing from the plugs. I do not understand the inner workings of the mag well at all, so I am not sure which parts are indicated as being potential problems now. The new coil is slightly bigger around and now I am no longer able to remove the condenser with the coil in place. The points are new and I filed and gapped them before I put the new coil in. Cap and rotor are new, wires are new. I need to check tomorrow to make sure I have good wire connections. I towed the tractor the rest of the way home with help from my sister, so now it is in a handy spot to work on. Any advice will be very much appreciated. Zach
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
