Re: Red, I need your help!!!!
Posted by The Red. Uh oh. on June 03, 2000 at 07:38:19 from (12.75.196.169):
In Reply to: Red, I need your help!!!! posted by pharmAL on June 03, 2000 at 07:29:39:
Al bolt the pump back up against the frame. Clean the drive shaft as well as you can. Those pins go through two collars that you must slide towards each other so that driveshaft will come out. It is slotted into the coupler on either end. Look at Wardner's scan in the post below. He has an explosion view of the liftall. You will see what the driveshaft looks like.
Post A Followup
: Re: Re: Red, I need your help!!!!
