Re: *Super M Again*
Posted by tractorsam on June 30, 2010 at 17:45:54 from (24.222.151.46):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
If the points were closed when you did this test that would be
entirely normal. The purpose of the points is to take the power to
ground, the coil is the load, and so after the load the voltage will
be zero (it's voltage rather than current that you see with the test
light) if the circuit is complete (points closed). If you have an
assistant crank the tractor while you watch the light (connected on
the distributer side of the coil) you should see it flash as the points
open and close. Hope that helps, Sam
